P
perfect1000k
hi there what is the maxium lengh of meter tails you can use is there anywere in the regs it states what it is any help would be great cheers
Discuss maxium lengh of meter tails ?? in the Australia area at ElectriciansForums.net
From cutout to ccu should be no more than 3 meters unless you install a switchfuse before the ccu.
thanks for the replys lads looks like i owe someone a bacon on toast in the morning lol
also why have i seen tails 25mm running from outside meter box (white one on side of house ) running into the cavity across the loft down into the airing cubord (bungalow) about 15 meters in all ?
seen this on a few council houses ive worked on in past 6-7 months
Reply to maxium lengh of meter tails ?? in the Australia area at ElectriciansForums.net
