We recently were tasked with doing a pilot run for upgrading the exterior lighting at some retail locations. My guys removed existing wall packs and reinstalled new LED wall packs. There were a few different wiring methods used. Some of the existing fixtures were powered by MC coming through the brick and into the back of the fixture with no connectors. Some had a handi-box sunk into the wall with the #12 coming straight through the knockout and into the fixtures.
My guys removed and reinstalled the fixtures exactly as they were originally mounted and the customer had a local electrician come behind and spot check and called us out for this not being to code.
My questions/concerns are this.
1) Would we be responsible for chipping away at the brick to make room for a connector to attach the MC to the fixture, given that these wiring methods were pre-existing? Would an insulated bushing and no connector be sufficient?
2) With the luminaires having a box mounted inside the wall, would an insulated bushing be sufficient?
