T
trev
And on that note, I'm out.I need to know how to design to avoid nuisance trips.
My goodness
Why are they on plugs and sockets? Factory machinery is much safer if it's fixed and hard wired.These will be fed off plugs and sockets, regs indicates RCD requirement.
The boss only wants them until the day the first one trips.Boss wants RCDs.
It isn't the job of an electrical designer to prevent or protect against reckless or negligent behavior or willful damage by the machine operator.Operators are a f£$^%ing liability and are so reckless with equipment everything in this factory needs RCD protection.
Most of the equipment will be hard wired. Some parts of the production line get changed, they will be on plugs/sockets
I know, hence wanting that not to happen unless it is stopping someone getting a shock
some plugs are interlocked...by means of the isolator switch...Why are they on plugs and sockets? Factory machinery is much safer if it's fixed and hard wired.
All the kit I can find clamps only the earth (which I would assume is only useful for single phase with no potential parallel paths).
I'm wanting something like Marvo described. Does anyone know where to get one, or who makes them?
incidentally for testing 3 phase equipment you need plugs that are wired internally...both in star...and delta....depending on whether or not a neutral pin has been provided.....dont forget that a pat tester measures all live conductors to earth on IR....Hi,
I have been tasked with rewiring most of the machines in a factory.
Due to the age of the equipment and usage I believe residual current protection is a good idea.
This presents an issue with how they want them wired.
Currently we have cables hanging from the ceiling at multiple points of the production line.
The want rid of this and want each machine in the production line to power the next.
My idea is to fit a dist board at one end and feed them off each other.
The only issue I have is what do I rate the RCD as?
The easy approach is to fit a 30mA RCD as the incomer and feed everything off individual mccbs.
However I do not know if these machines will cause nuisance tripping.
So the short version of this question is how can I measure the residual current on a 3 phase machine?
I've seen a PAT tester that could do single phase, but nothing for 3.
At the moment, the best idea I have (which sucks) is to get a settable RCD and keep reducing the current until it trips. This obviously does not take in to account any fluctuations in the device!
So do any of the sparks know how to do this properly or have any advice to offer?
Thanks,
Inteificio;922534 who do not understand electricity.[/QUOTE said:Sorry but that's just too good to resist.
Those familiar with my sense of humour will know what I'm getting at
