Breaking news
Fork truck runs over extension lead
"Unfortunately, just one of those things we can't protect against"
I just wish there was some way we could
If you are being told to fit RCD protection use something like this
Earth Leakage Relays
fit one for each machine on it own dedicated feed (if required) and set to maximum setting (30A) and maximum time delay. You will have fulfilled the instruction you have been given and shouldn't get nuisance tripping.
Wow lots of questions at once.
Reason for RCDs, many.
For a quick answer.
These will be fed off plugs and sockets, regs indicates RCD requirement.
Boss wants RCDs.
Operators are a f£$^%ing liability and are so reckless with equipment everything in this factory needs RCD protection.
No reason not to add additional safety, if something is designed correctly, it won't cause an issue, but stop an accident.
"and i smell a cascading feeds epic here as well..." - Each piece of equipment will have it's own dedicated feed. Not sure what you meant though, so care to expand?
What happens when one machine packs up, it takes out another 3 or 4 or whatever? " That's a good thing. If one item on the production line has an electrical fault the production line stops.
Des, I know little about mining, so your references are lost on me.
Basically a packing machine. Main boxer -> conveyor -> metal detector -> conveyor -> weigher -> LS.
RCDs are going in, no choice on that.
I need to know how to design to avoid nuisance trips.
So what does he suggest you do?
"So if I fit an RCD its ok to wire my factory in extension leads ?"
Clearly not, however if you have to deal with stupid people it means they are less likely to be able to hurt themselves.
So what does he suggest you do?" - He is a mechanical engineer.
So why is he not listening to your professional opinion?
This is the thing Dillb, the boss may be asking for rcd's but as the electrician surely it would be our job to sit him down and tell him the correct way of doing it.
Simple answer.
Get the "boss" to design the install, and sign for it, you install and test to his spec, and put notes to the cert with regard to your reservations, job done.
He thinks he knows better so, get him to put his signature where his mouth is.
IF he is registered with one of the Engineering Institutes, and he works outside his area of competence, or works incompetently then there can be ramifications.
Plus the HSE would not take it lightly if something went wrong, with him being a registered Professional Engineer.
The ego of management usual far outweighs their intellectual capacity to understand the simple .... or to save face, I said to do it this way so JFDI
You can’t beat having a mechanical bod as senior engineer:
They have to do what you say.
You do what you want to do.
Get the cheque book out when you want something, so long as you make it sound plausible.
Haven’t a clue what you’re doing most of the time so can’t ask awkward questions.
What more do you want?
The down side, when it all goes wrong you’re the first to get an invite to the arse kicking party. If they’re anything like mine, he’ll be on holiday the day of the party.
