I'm looking at upgrading my Halogen MR16 to LED.
Purely from a hassle factor I'm thinking to convert to GU10 LED as insulation test are so much easier.
Any reason why you might choose MR16 LED over GU10 LED?
Thanks,
One less electronic device to go wrong
One less electronic device to power and lose energy through
More to go wrong with MR16
Greater amount of choice with GU10
Can I stop now?
Thanks,
What's a halogen lamp? :)
Curious as to know how changing to LED, makes life easier when testing; install wiring, test circuit, install luminaires. Just saying.
lol I think it means easier to test a 240v system to testing low voltage and I am like everyone else I have never fitted MR16 unless it one of those dam fan lights I hate so much and the customer got it ! GU 10 all the way for me ! I never really understood the idea people had that low voltage was saving them money lol
Yeh G9s that come with every customer purchase 'colours' range from B+Q. Had to fit 9 in one day - glad to go home.
Edit . Sorry D00DY thought you meant LED lamps other than GU10
Once agreed to change a light after work for a family friend for the cost of petrol.
Of course it was one with 12 glass covers to be fitted and fiddly little lamps that explode as soon as you touch it with your skin.
And it had to be adjusted so it'd fit the rather low ceiling in the living room. Fun times.
I fitted 50 GU10 downlights in one ceiling in one day wired on 7 circuits to represent 7 constellations of the stars and in the centre was a large round light that could be lit in quarters to represent the moon looked lovely but never again lol
I've seen one of them in a bathroom with fibreglass. Thought it was pretty funky.
Not so much to install:D
Curious only 'cos we are testing the circuit, not the luminaires. Why do people rate something that's clearly not obvious, and not post their reply, or have I missed that?
I'll bet you stood back when powering that up - 50watt halogens would vaporise you if all 'constellations' on at the same time!
I'm not sure I fully understand your post, but to clarify. Moving to LED is background information. The relevant part is moving from MR16 to GU10.
The reason I say it's easier is when doing EICR on GU10 I simply remove bulbs and can complete all insulation resistance tests. But with MR16 I can only do Live conductors connected together and earth, unless I want to disconnect the transformers.
The reason for going for MR16 16 years ago was because I was told they give off a better light. But now I'm thinking I was suckered into "The Emperor's New Clothes"
Kent
MR16 LED Vs GU10 LED
Michaelwgroves,
Reynard,
