Hello,
I am looking for some advice please. I want to get a commando socket installed in my front garden to plug in an EV car charging device where the amps is adjustable from 9A,10,,16 and 32A. (https://www.amazon.co.uk/EVDANCE-Charger-Waterproof-Electric-Commando-Black/dp/B0D2QDNWR6?th=1)
I want to keep the connection separate from my main household circuit. I inquired with one of the electrician and he saw the pictures and videos of the house. First, he said that not to have a separate unit for the commando socket and then he said that it should be done in the same unit as house. The house unit is old, so he said that the whole thing will need a replacement and it would cost £1700, which is 3 times higher than my budget. I was told to get a commando socket from a dedicated unit. Can anyone possibly put me in the correct direction here ?
As an Amazon Associate we earn from qualifying purchases.
As yet I haven't seen where BS7671 says BS EN 60309-2 sockets specifically cannot be used in a "household" or "domestic" setting. It does acknowledge they are industrial connectors, but I haven't understood it as a specific "not permitted" requirement (yet!)
I accept that it does specify (in section 533.1.201) that domestic sockets must be shuttered (though there are some exceptions allowed, like clock connectors)
My issue is that BS 7671 Section 722 'Electric Vehicle Charging Installations' says interlocked commando sockets can be used. Are we to conclude those requirements are only applicable to industrial sites. It doesn't say that.
It is in the Code of Practice for EV charging.
Upvote 0
My problem is that I don't accept that. In fact the commando type BS EN 60309-2 is actually listed in the table of acceptable sockets.
The issue for me hinges on the bit that says "Every socket for household and similar use shall be of the shuttered type....." and whether the use of interlocked commando sockets (contacts isolated before exposure) can be an allowable substitute for shutter protection.
My argument on safety stands whether commando is prohibited full stop or interlocked are prohibited.
Again if you have a house converted to a shop or a restaurant downstairs and flats upstairs you wouldn’t normally change the electronics at all but installing a commando in the shop part would be no issue. Danger profile is exactly the same as installing a charger in a driveway, garage etc. If anything given the commando in the shop part would be in the building with the flat itself the risk profile is higher.
Worst case a commando in a residential setting is a breach of the regulations but not anything to do with safety
Upvote 0
The 13A is not designed for continuous draw and having used 13A charging myself the pins heat up a lot. The commando on the other hand is designed for continuous draw.
Just as a matter of interest, is the socket you speak of an "EV" rated one? I gather they are designed for o poorer power factor rather than for more current carrying capacity, so not sure if they would behave any differently?
Eg: 13A EV Sockets Compliant with BS 1363-2 EV - https://toughleads.co.uk/products/ev-socket?
Upvote 0
The pins on the plug heat up and radiate to the socket. The socket is not burning hot but the pins are immediately when removed from the socket. No burns detectable on the plug or the socket. Don’t know what long term damage it could do if any.
Upvote 0
What has actually happened here is an admission that sockets complying with BS1363 have not fit for purpose for the last 60+ years. (I deliberately exclude the first 10 years when sockets were made to a much better standard.
Upvote 0
Corrected that for you as it is often overlooked when DIY is involved
Well of course it needs to be tested but I was neither talking about diy nor testing.
The important thing we agree on is that the risk is the same whether in a residential or commercial setting as long as the wiring is done properly and properly tested. I.e what is not accurate is the conflation that non compliant is inherently unsafe. It may be but doesn’t have to be.
Upvote 0
So I have asked another electrician and his response.
That's not correct, it's absolutely fine to use a commando as a charge point outlet in any setting, there isn't any restriction, it's in Section 722.55.101.0.201.1((ii) and (iii) of BS7671, the Wiring Regulations. BS EN 60309 is the standard for commando outlets.
As far as the type of outlets can be used anywhere else in an electrical installation BS7671 isn't so specific, although it mentions some, the general principle is that if something isn't specifically prohibited by a clause in the regs then it's permitted, as long as the installer is content that its no less safe. This is the generic bit on standards for electrical equipment that can be used in an installation. He referenced 511 “compliance with standards”
Upvote 0
They clearly do not have the Code of Practice or if they do they have never read it.
Upvote 0
So we have a terrible situation now for Jo public. First if he wants to use the commando solution he is going to have to ring around a bunch of electricians to find one that doesn’t agree with you and then again do the same thing when it comes to needing an EICR.
Upvote 0
But I doubt that when the 13A socket was designed it was envisaged that it would have a 10 - 13A continuous load for possibly 10 hours or more connected to it
Upvote 0
No different really from getting legal advice. if you dont like the advice, choose another, eventually you will get the advice you already wanted... lol
Such is the state of endless "regulation changes" making it virtually impossible to carry out an EICR with certainty that installations were compliant at the time but not if installed today. Note how many posts are about EICR's and the endless backwards and forwards between electricians.
All i can say is that with Gas and Fgas, it is straight forward (mainly) and is not changing constantly (apart from the Fgases allowed in new installs, lol
Interesting comparison with gas is the demarcation between Domestic and Non-domestic, I am non-domestic but i have to deal with commercial boilers in large houses because the Domestic guys are not allowed, equally i cannot touch a domestic boiler in a domestic setting even though i would have dealt with that same boiler in a commercial setting. Apart from that its all rosy in the Gas/Fgas world.
Upvote 0
There is no terrible situation as far as I can see.
Upvote 0
