Over the summer we had some single phase workshop gear removed, and in it's place was delivered a second-hand 3-phase lathe. At first I was going to drop in a new circuit, as naturally, the single-phase circuit that exists is useless. However, this new lathe is going right next to another lathe we have that is fed off a C16 MCB. This circuit terminates in a MEM Exel 20A switch disconnector, which the current lathe ties in to.
The current lathe is 5.1A and the new lathe is around a couple amps from memory - can anyone see an issue with dropping the new lathe in to the same switch disconnector (except that to isolate one for maintenance means to isolate them both - not an issue)?
Thanks,
Thanks,
