richard harris in the film juggernaut. unexpolded bomb.
you are going to have to test the circuit then with an mft then to identify the fault.
i'll lend out my neon screwdriver for a modest fee.
i was suspicious about if i had correctly identified the switch so on top of using a continuity/polarity indicator i have nicked a MFT from someone to test the continuity and it does confirm its the switch wire. got a reading and then flipped the switch to get an open circuit so i am going to try testing the circuit more indepth later in the week.I am wondering if i should try and replace the switch to see if its the issue, will post back later with an update.
not sure if this would be considered good practice, but have you tried connecting the incomming live and neutral to the lamp connectors directly missing out the switch and switch wire altogether to see if that trips the breaker.
Is this your own porch or not? If its wired in new colours it not that old a wiring then. I take it all was ok before the light was removed?
I’m sorry but two cables doesn’t give a lot of options.
If you’ve borrowed a MFT do you know how to use it?
A competent electrician will find the fault within ¼ hour.
If building modifications have been done the chance is cable damage!
kyranocat,
Knobhead,
