Discuss Notify building control??? in the Business Related area at ElectriciansForums.net
If you do not need to notify then you just issue the cert to the customer as normal.
if it needs notifying, then this is all done on line via the scheme providers website in the secure area.
So if it doesnt need to be notified you dont need to tell your scheme provider anything at all... you just test the work done and give a copy of the results the the customer, end of ???
They dont get a cirtificate of compliance?
A customer has a big bedroom with only 1 pendant in the middle of the room, He asks you to make 2 lights in this room, making 2 pendants one either end of the bedroom.
What our my options as the CU is to 16th so lighting is not RCD protected?
Also as its only minor works and in a bedroom its not notifiable... correct?
But still needs a MWC giving to the customer..
Maybe you could bump the thread where Eng54 and myself had a discussion on parallel cables, Dan? Everyone would love to read that one again...... Only 144 posts. :)
Bump it mate. Bump any that were good because Google will appreciate it. The URLs have changed so I'm getting them indexed properly.
haha Only joking Dan. People might hire a hit quad to come and get me if I bump it.... :)
I forgot about part 2 Archy. :)
Reply to Notify building control??? in the Business Related area at ElectriciansForums.net
Evening all, Just a quick question, I am an electrical maintenance engineer and have 18th edition, inspection and testing and so on, so I get...
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
Hello, I am in the process of purchasing a property. I have made an offer, and after my own little survey, I noticed a few issues with the...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hello, I bought a new build and noticed the upstairs MCB is controlling some sockets on the opposite floor, so if I flick the upstairs MCB it's...
