Discuss On small jobs charging for cable in the Business Related area at ElectriciansForums.net
Hi all
I was just wondering how every charges for cable on a small job? Let me give you and example, you are asked to replace 4 down lights, but one 1 of them you fined that the cable is to short so you replace that cable back to the next downlight, Normally i would just charge for sundries £20 but the customer refused to pay the sundries charge as " i only use a couple of meters of cable, and he shouldnt have to pay that" and it got me thinking does anyone charge per meter of cable ?
Maybe you should put it in the quote. "If cable needs replacing then a charge of £? per meter" or something like that.
Don't try and rip them off by charging £20 for 2 meters of cable....
if it was just a couple of yards, i'd not charge as usually have offcuts on the van. anything over 10 ft. i charge with sundries. XXp/m
The sundries was to cover, cable , few jbs among few other odd bits i had used off the van, otherwise yes i agree £20 for 2 meters of cable bit excessive.
You said the job was to replace 4 down lights??? Strange that you needed a few junction boxes as well as additional cable for this.
Anyhow... again, I'd just put something in the quote for future jobs.
If your customer is that pedantic, I wouldn't work for him again.
You had to use a new piece of cable for whatever reason... too short, or damaged... it all needs paid for. Your joint boxes, green sleeving… use of your stepladders, fuel and van upkeep...
I just list "additional materials" on my invoice and pluck a number out the sky
I personally would never charge for 2 mtr of lighting cable . Have loads of off cuts for such jobs and just throw in without even thinking about it...
Anything over 4mm sq I will charge by the yard
I don't list materials by item on my quotes/invoices. I don't normally break it down into materials and labour either.
The price is the price. Take or leave. If I needed a couple of metres of T&E I'd just throw it in. I don't like making my prices that tight that I'd need to charge extra for something so small!
Depends on the size of the jobs... if it's one or two screws, I tend to not charge but for bigger jobs I'll add a line to the invoice 'Consumables' and make a reasonable estimate of the cost of all the parts I've used.
Cable... charged by the meter with all lengths used being slightly over estimated. I certainly wouldn't charge £20 for 2m of cable.
I don’t agree, 2 meters of lighting cable, using this example is well under £1.00 so why be awkward and add this to an agreed price?
Makes no sense
I didn't suggest to add to an agreed price, but to include it when pricing.
Reply to On small jobs charging for cable in the Business Related area at ElectriciansForums.net
So a few months back I fitted an outside socket , the customer has messaged me saying it doesn’t work and I need to come and fix it etc. do I...
Hi guys. It would be really useful to run this past you and get a consensus/input from you for what would be a realistic amount to charge for an...
I am stuck on another job for next 2 months . Friend has maybe 14 max down lighters and maybe 2 pendant points . Wiring in loft space is a bit...
So I just started out recently and I’m struggling with what to price myself at. It’s worth noting I live in the east London area and I’m looking...
