Discuss On small jobs charging for cable in the Business Related area at ElectriciansForums.net
Hi all
I was just wondering how every charges for cable on a small job? Let me give you and example, you are asked to replace 4 down lights, but one 1 of them you fined that the cable is to short so you replace that cable back to the next downlight, Normally i would just charge for sundries £20 but the customer refused to pay the sundries charge as " i only use a couple of meters of cable, and he shouldnt have to pay that" and it got me thinking does anyone charge per meter of cable ?
Maybe you should put it in the quote. "If cable needs replacing then a charge of £? per meter" or something like that.
Don't try and rip them off by charging £20 for 2 meters of cable....
if it was just a couple of yards, i'd not charge as usually have offcuts on the van. anything over 10 ft. i charge with sundries. XXp/m
The sundries was to cover, cable , few jbs among few other odd bits i had used off the van, otherwise yes i agree £20 for 2 meters of cable bit excessive.
You said the job was to replace 4 down lights??? Strange that you needed a few junction boxes as well as additional cable for this.
Anyhow... again, I'd just put something in the quote for future jobs.
If your customer is that pedantic, I wouldn't work for him again.
You had to use a new piece of cable for whatever reason... too short, or damaged... it all needs paid for. Your joint boxes, green sleeving… use of your stepladders, fuel and van upkeep...
I just list "additional materials" on my invoice and pluck a number out the sky
I personally would never charge for 2 mtr of lighting cable . Have loads of off cuts for such jobs and just throw in without even thinking about it...
Anything over 4mm sq I will charge by the yard
I don't list materials by item on my quotes/invoices. I don't normally break it down into materials and labour either.
The price is the price. Take or leave. If I needed a couple of metres of T&E I'd just throw it in. I don't like making my prices that tight that I'd need to charge extra for something so small!
Depends on the size of the jobs... if it's one or two screws, I tend to not charge but for bigger jobs I'll add a line to the invoice 'Consumables' and make a reasonable estimate of the cost of all the parts I've used.
Cable... charged by the meter with all lengths used being slightly over estimated. I certainly wouldn't charge £20 for 2m of cable.
I don’t agree, 2 meters of lighting cable, using this example is well under £1.00 so why be awkward and add this to an agreed price?
Makes no sense
I didn't suggest to add to an agreed price, but to include it when pricing.
I mainly do light commercial for a handful of clients, if I need cable a reel gets charged to that job regardless if its 1m or 100m.
I don't otherwise charge for cable, within reason.
Never had a complaint.
I can see domestic being a right PITA using this approach.
I'd double and VAT purchase price/meter and charge on a meter used basis.
Or you can suggest your customer goes to the nearest wholesalers and tries to get the meterage required and work out the cost for themselves.
I'm gonna start and charge an extra 5p to install a light fitting, to cover the cost of 2 screws I'll supply to do the job. If 2 red wall plugs needed that's another 4p.
Around 15 years ago I worked for a small maintenance company that would itemised it’s invoices like this...
Absolutely everything was itemised, and I mean everything
Even down to sleeving by the inch
I charge for everything, every wago, every meter of cable etc, etc, in fact I keep a job sheet and write everything on it. However I do tell my customers I will charge any extras at cost.
It’s my cable, and the customer has to pay for; I’m not a registered charity. Whether it’s shown on the invoice or added to the labour costs or something else. They ain’t getting it for free.
It’s alright for those of you, who have bigger companies and have probably already charged another customer for that reel of cable, and therefore feel ashamed of yourselves charging someone else, for something already paid for.
Us minnows have had that reel of cable, sat in the van weeks, burning a hole in our pockets.
I had a similar job recently to replace 6 down lights and found some damaged/short cables, before I replaced it, I explained to the customer that this would come under a charge of 'sundries' on the final invoice. But I always state a price for sundries on my quotes, with a caveat of 'any damaged, short cabling that may need replacing, that wasn't seen at the quote stage will be chargeable'
So how much is a fair price to charge for a few metres of 1.5mm
£5 , £10 ?
For 1 meter...
How much do you pay for 100m?
Divide that price by 100 and then double that figure. That should seem fair.
That’s the thing; quoting is a ‘fixed price’. If you then start adding extra bits without consultation with the client, it can get a little ‘messy’. Me personally, if I’ve checked everything and there’s no issues then a quote is fine. Estimates are good as they can remain (fully explained to the client) ‘fluid’ owing to any unforeseen major issues. Also, if I’m quoting, I always add a little ‘fudge factor’ on to the price to allow for little bits here and there.
at least it's in inches and not milli thingies.
what costs more a yard or 3 feet of cable....
at 10 bob a foot, both cost the same. but if a yard of cable is 5 bob a foot and 3 feet of cable is 10 bob a foot. then one costs twice as much as the other.
But inches are divided into 8 bits, or 16, or 32, or 64, not 100 bits.
I am but a simple bear and my head just can't grasp 1.97 inches. If you want to divide things into 100 use metric, if you want to use inches but be very accurate, use smaller traditional fractional divisions.
as im no-one of us over the age of 40 can visualise mm. 3 feet we can see. 900mm we need to use a dual tape measure. same when i want to print a photo. 8" x 6" fine. wtf is 205mm x 152mm.
Reply to On small jobs charging for cable in the Business Related area at ElectriciansForums.net
So a few months back I fitted an outside socket , the customer has messaged me saying it doesn’t work and I need to come and fix it etc. do I...
Hi guys. It would be really useful to run this past you and get a consensus/input from you for what would be a realistic amount to charge for an...
I am stuck on another job for next 2 months . Friend has maybe 14 max down lighters and maybe 2 pendant points . Wiring in loft space is a bit...
So I just started out recently and I’m struggling with what to price myself at. It’s worth noting I live in the east London area and I’m looking...
