There is no way you will ever keep moisture out of an enclosure of this kind, regardless of how much silicone you use. As already pointed out, condensation alone will make it damp inside. The only solution is to have a small drain hole. We had a saying back in the food factories..."You can't keep it out, so give it a way of leaving".
Hi Guys Thanks for the quick replies. Its plastic conduit I will be using with a female adapter. Does anyone know if there are any rubber seals available I could use between the adapter and the box to give a water tight seal or is a bit of silicone my best bet
Yes you can get 20mm rubber seals, they are usually used with stuffing glands. Can't see them being very effective with conduit adapters though.
As has been said, pvc solvent and silicone are your best bets.
in this situation, you need a plumber to assist.he'll drill a 22mm hole in the bottom of the box, then install a condensate pipe all the way round the house to feed into the furthest drain.
