Hi All, I'm doing remedial work for one property following unsatisfactory EICR to rectify C2 issues.
I'm slightly amused by some quotes left on the report by another electrician.
Here it is
"No accesible isolator switch for oven" C2
I had a look and found that the oven is 13a rated plugged in to a socket behind. You would need to unscrew it and pull it out to see the plug behind. Isolator switch might be handy but should it be classed as C2?
I've spoke to one electrician I know and he said it shouldn't be issued as C2
Any other views are welcome
Here it is
