fast set, dirty water. like s&&t to a blanket .Thistle bonding, mixed tight
house of straw, three little pigs .Mud and small sticks
Whip up some strong compo and bed the box into that, when compo is set, drill and screw as normal.I have chased out some 35mm and 47mm metal back boxes into some walls made up of granite and mud. Some of the chases have gone too deep and was wondering what people use to pack out the boxes and to even them where the chased out box is uneven?
Cheers
Hi Pete, what do you mean when you say compo? Not familiar with the term. CheersWhip up some strong compo and bed the box into that, when compo is set, drill and screw as normal.
Sand, Cement and water, Brickie's brick laying mix but a bit stronger, add a dash of Washing up Liquid to make it more pliable. Slap it in the box hole, set box at the right depth and height allow to set then drill a fixing hole and strengthen the fixing, jobs a good one. I used to scrounge a bucket of "muck" from the cement mixer.Hi Pete, what do you mean when you say compo? Not familiar with the term. Cheers
Thanks Pete sounds ideal I will give that a go.Sand, Cement and water, Brickie's brick laying mix but a bit stronger, add a dash of Washing up Liquid to make it more pliable. Slap it in the box hole, set box at the right depth and height allow to set then drill a fixing hole and strengthen the fixing, jobs a good one. I used to scrounge a bucket of "muck" from the cement mixer.
A pointing trowel was always part of my first fix tool bag.
It saves faffing about packing back boxes with bits of wood etc, need to wait for the Compo to harden, but on new builds it can save so much time. Good luck with it, sure iy will work for you.Thanks Pete sounds ideal I will give that a go.
Muck,Compo, S---, Mortar, lots of names, we just called it Compo down in Bath Bristol area, why? I don't know, just know "go and get some Compo" was the order of the day when fitting back boxes, some Sparks used "Thistle Bonding coat" never rated that myself, couldn't beat a dollop of Compo.What is it called Compo? I have never heard of that.
Compo up here too Pete. I suppose it is short for compound.Muck,Compo, S---, Mortar, lots of names, we just called it Compo down in Bath Bristol area, why? I don't know, just know "go and get some Compo" was the order of the day when fitting back boxes, some Sparks used "Thistle Bonding coat" never rated that myself, couldn't beat a dollop of Compo.
Could be but this Compo was nothing more than a strong Mortar mix.Compo up here too Pete. I suppose it is short for compound.
All these new fangled compounds, knock the knock outs you require, fit Grommet slap it in the hole, slap the box in, level it, fill in around the box, job done.That's what we call it too. Same stuff .![]()
Compo every timeWell I'm going to show off now and say I have never had to do that
When I see the brick/stone crumbling behind the back box I do the following...
1. Panic.
2. Slowly stop panicking.
3. Slow everything down and become very gentle with the remaining brick.
4. Drill new holes in the back box itself if needed, where I know there is good brick behind.
5. Drill out new holes in the remaining brick, starting with a smaller drill bit and working up, preferably not with hammer action.
6. Huge sigh of relief when 2 of the screws take a firm hold!
7. Cup of tea.
I'm not allowed near expanding foam after an incident involving the Mrs and a considerable amount of it in her hair
Yeah that looks similar to what happened. My Mrs is a damn sight better looking though!!
Sometimes CleggCompo every time
Anything with more than one ingredient is a compound...as with pyro compound...….but don't use that cos it'll take an age to solidifyCould be but this Compo was nothing more than a strong Mortar mix.
1. Panic.
7. Cup of tea.
sadly, he's better looking than me. a bit greyer maybe, but al least i'm still alive.That’s a nice selfie Tel - and what I always imagined you to look like!
