Discuss Packing out back boxes in the UK Electrical Forum area at ElectriciansForums.net
Well I'm going to show off now and say I have never had to do that :smirk:
When I see the brick/stone crumbling behind the back box I do the following...
1. Panic.
2. Slowly stop panicking.
3. Slow everything down and become very gentle with the remaining brick.
4. Drill new holes in the back box itself if needed, where I know there is good brick behind.
5. Drill out new holes in the remaining brick, starting with a smaller drill bit and working up, preferably not with hammer action.
6. Huge sigh of relief when 2 of the screws take a firm hold!
7. Cup of tea.
Compo every time
I tend to use drywall mix for the odd issue like this, I find the thistle and the knauf stuff the best. The half hour set stuff is really good for quick patch too, low shrinking and you can finish it up with ease too!
Had that the other day on an old cottage, rcd kept tripping low n-e insulation resistance found it on a badly corroded socket and box IMG_20190318_1651435.jpg
Could be but this Compo was nothing more than a strong Mortar mix.
Anything with more than one ingredient is a compound...as with pyro compound...….but don't use that cos it'll take an age to solidify;)
Get some long 3.5's.
Could sort some bonding out......but only water, no gas.:rolleyes:
1. Panic.
7. Cup of tea.
8. Receive -------ing from the foreman/site agent etc for taking forever to fit one box.
Reply to Packing out back boxes in the UK Electrical Forum area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
I am wiring up a new kitchen and conservatory. I'm not sure why I checked continuity between line and the metal back box of the light switch, but...
Hi, This post is about my concerns with medical IT socket outlets and want to alert you all if you are fitting them in a hospital. The current...
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
