Guest viewing is limited
I have chased out some 35mm and 47mm metal back boxes into some walls made up of granite and mud. Some of the chases have gone too deep and was wondering what people use to pack out the boxes and to even them where the chased out box is uneven?
Cheers
Cheers
Whip up some strong compo and bed the box into that, when compo is set, drill and screw as normal.
Hi Pete, what do you mean when you say compo? Not familiar with the term. Cheers
Sand, Cement and water, Brickie's brick laying mix but a bit stronger, add a dash of Washing up Liquid to make it more pliable. Slap it in the box hole, set box at the right depth and height allow to set then drill a fixing hole and strengthen the fixing, jobs a good one. I used to scrounge a bucket of "muck" from the cement mixer.
A pointing trowel was always part of my first fix tool bag.
Thanks Pete sounds ideal I will give that a go.
It saves faffing about packing back boxes with bits of wood etc, need to wait for the Compo to harden, but on new builds it can save so much time. Good luck with it, sure iy will work for you.
What is it called Compo? I have never heard of that.
Muck,Compo, S---, Mortar, lots of names, we just called it Compo down in Bath Bristol area, why? I don't know, just know "go and get some Compo" was the order of the day when fitting back boxes, some Sparks used "Thistle Bonding coat" never rated that myself, couldn't beat a dollop of Compo.
Compo up here too Pete. I suppose it is short for compound.
Well I'm going to show off now and say I have never had to do that :smirk:
When I see the brick/stone crumbling behind the back box I do the following...
1. Panic.
2. Slowly stop panicking.
3. Slow everything down and become very gentle with the remaining brick.
4. Drill new holes in the back box itself if needed, where I know there is good brick behind.
5. Drill out new holes in the remaining brick, starting with a smaller drill bit and working up, preferably not with hammer action.
6. Huge sigh of relief when 2 of the screws take a firm hold!
7. Cup of tea.
1. Panic.
7. Cup of tea.
Compo every time
I tend to use drywall mix for the odd issue like this, I find the thistle and the knauf stuff the best. The half hour set stuff is really good for quick patch too, low shrinking and you can finish it up with ease too!
Had that the other day on an old cottage, rcd kept tripping low n-e insulation resistance found it on a badly corroded socket and box IMG_20190318_1651435.jpg
1. Panic.
7. Cup of tea.
8. Receive -------ing from the foreman/site agent etc for taking forever to fit one box.
Cornwall
Packing out back boxes
Longers,
HappyHippyDad,
