gazdkw82
All electrician's within my works have been carrying out PAT testing on numerous appliances and extension cables for a while now as directed by our supervisors.
Only a few lads have done the PAT testing course many years ago and we are unsure if you have to have taken the PAT course or is an electrician deemed competent enough to perform such inspections?
The course is worth doing, and so is obtaining the current code of practice. A big part of 'PAT testing' is inspection and logging of results.
Remember it's not called PAT testing as well. It's ISITEE. PAT is a misleading name, as it doesn't just apply to portable appliances, and it often doesn't involve testing.
And as above - its boring and very competitive in terms of price. OK as a side line.
..cos its a trade secret -that I just blabbed..
A decent tester will do this and update all the item records in the log helping you to retain the will to live. :)
An Electrician should be competent enough, not to need to have their tools and equipment pat tested.
Saying that though, I often see testers just pull their jumble of leads out of a bag, plug them in and start testing, without even glancing at the leads to check they look ok.
gazdkw82
leicester
United Kingdom
Electrical Engineer (Qualified)
PAT testing - suitably skilled
gazdkw82,
Deleted member 26818,
