Got a rewire on a house referb for one of my builders- but unfortunately ground floor is solid- so will have to use 1st floor floor and drops down for ground sockets etc then theres a loft above for 1st floor lighting
all white plastic
builder to make good/ core holes etc
spec as follows:
GROUND FLOOR
Current Garage/to be bedroom
Install 1x 10way dual RCD metal MK consumer unit
Install mains gas and water bonding
Testing and certification on completion and after full payment is received
1x pedant light + 1x light switch
4x d.sockets
Current Garage/ to be bathroom
1x ceiling light+ 1x light switch outside door- customer to provide a bathroom suitable fitting
1x extractor fan+ isolator switch outside door -builder to provide 100mm core hole
Kitchen/Living Room Open Plan
10x downlights -to be split on 2 switches 1way only
Living Room side
5x d.sockets
1x coaxial outlet- runs back to an amp in loft (standard TV- not sky/VM) (not including any AV etc)
Kitchen Side
4x d.sockets (for general use)
Appliances:
1x independent cooker circuit with isolator switch
1x under worktop single socket for gas hob (different if all electric)
1x under worktop single socket for washing machine- with isolation switch
1x under worktop single socket for dishwasher- with isolation switch
1x under worktop single socket for microwave- with isolation switch
1x single socket for fridge/freezer
1x single socket for extractor hood- with isolation switch- builder to provide core hole and ducting
1x switch fused spur for boiler- supply only/not including controls
1x mains operated heat detector
Ground Floor Front Room
5x downlights+ 1x switch
6x d.sockets
Ground Floor Hallway
4x downlights+ 1x 2gang 2way light switch (1-ground hall, 2-1st landing)
1x d.socket
1x mains operated smoke detector
1ST FLOOR
1st Floor Landing
1st Floor Main Bathroom
3x downlights+ 1x light switch outside door
1x wall mounted extractor fan+ isolator switch outside door -builder to provide 100mm core hole
Master Bedroom
4x downlights+ 1x light switch
3x d.sockets
Master Bedroom En-Suite
Bedroom 1
1x pendant light+ 1x light switch
3x d.sockets
Bedroom 2
3x d.sockets
Bedroom 3
3x d.sockets
Outside
1x PIR security light on rear wall of house
1x PIR security light on side wall of house
TOTAL
£4,835.00
Possible extra’s not included in the spec from builder
Shaver sockets in bathrooms
Porch light
Outside socket or power to shed etc
BT point
Dimmers
Supplies for UFH
not sure if I should 20% it due to ground floor not being usable....
whats your guys ball park?
all white plastic
spec as follows:
GROUND FLOOR
4x d.sockets
Living Room side
5x d.sockets
Kitchen Side
Appliances:
- Cooker switch isolator -to be located in wall unit
- Grid switch controlling appliances
6x d.sockets
1x d.socket
1ST FLOOR
1st Floor Landing
Master Bedroom
3x d.sockets
Bedroom 1
3x d.sockets
Bedroom 2
3x d.sockets
Bedroom 3
3x d.sockets
Outside
TOTAL
£4,835.00
Porch light
BT point
Dimmers
Supplies for UFH
