3435hobiton
Hi, could someone advise me of the safest procedure when pulling live meter tails from the isolator switch at the consumer unit. I know about switching off the main switch to take out the load, but will not be cutting the seal and pulling the fuse from the cut-out. On this occasion I need to pull out the live first... connect to a Henley block and then the neutral and do the same. When reconnecting I will connect the neutral first and then the live. I was wondering if anybody could offer any helpful advise that I may have overlooked.
Regards Paul
Hi, I'm not bypassing the meter... I'm repositioning the consumer unit 3 foot up the wall. I'm a fully qualified electrician with 2330 levels 2&3, the 17th edition regs and the 2391. I just asked a question and was hoping somebody would offer a constructive answer... not accuse me if being a criminal!
It's one of those things that you need to be shown how to do rather than be told,get it wrong and it's half a day out with the undertaker,either leave it or pull the service fuse if you really don't want to involve dno
So you should be fully aware of safe isolation, no excuses. How would your family amd friends feel if itvwent wrong and you met your maker just because you csnt be bothered to do something properly?
Thanks Philip, has any Electrician ever been prosecuted for pulling the service fuse?
No not that I know of,they only get upset if you break the meter seals,I usually reseal when I have finished anyway,where are you?
3435hobiton,
davesparks,
