bigspark17
hi. I have a range electric oven rated at 11.1kw so am running 16mm t&e due to distance & would like opinions on what isolators i could fit. The flex on the range is 10mm 3c so need a large enough isolator to take these comductors. Also positioning of the isolator?
If your struggling could you not fit a contactor at the DB then fit a switch above the worktop to isolate it?
I do like that idea. And in this instance would be achievable as im running new supply to cu anyway. I could connect flex to t&e in an adaptable box under plinth. But do i need an isolator at worktop level. I always do fit them. Was contemplating a rotary isolator under or in the plinth.
bigspark17
wales
United Kingdom
Electrical Engineer (Qualified)
Range cooker isolator.
bigspark17,
Midwest,
