Discuss RCD keeps tripping in the Australia area at ElectriciansForums.net
A
Andy B
If a board has an RCD as the main switch and no main earth connected would this cause an RCD to trip whenever something is plugged in?
Andy the answer to that is No, but why is the earth not connected and how come the installation is being used without a Main Earth ? :eek:
Its OK its not being used (much). I powered up a ring main, plugged in a phone and it kept tripping after a minute. Once I connect up the whole installation (including earth rod) and power it up I`m obviously going to have tripping???
yeah i know its dangerous i left it all isolated, its a tt system thats getting connected to an earth rod tomorrow. i think i might have not connected the 2 neutral bars up correctly i was in a rush when i left. i`ll just have to check then.
thanks for your help.
Reply to RCD keeps tripping in the Australia area at ElectriciansForums.net
Hi, I seem to have an RCD that keeps cutting the power at random times without actually tripping, if I reset it, the power comes on and will stay...
My friend just moved into a new build flat and its for a disabled person with a hydraulic lift to go to the upper floor. There was/is a leak...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
