Discuss Recommendations for a Voltage Indicator and Proving Unit in the Electrical Tools and Products area at ElectriciansForums.net
RDB85
Trainee
I’m looking to save for a Safe Isolation Kit, we done the Safe Isolation procedure in College using a Martindale Kit. But would anyone have any recommendations for a kit to buy? The Martindale was good but I’ve seen a few other manufacturers that seem to offer more features but are they worth it?
Fluke for my money, good solid kit. Bought a kewtech for a trainee and it seems to give erratic results, making beeps and going red when there is no voltage. Another trainee bought himself one and same thing. Anything else is downhill from there.
Megger TPT320 is what I use, decent bit of kit, can pick them up online around £60 and a proving unit around £45.
Megger looks to be a good piece of kit.
[automerge]1601502366[/automerge]
Any particular model? I’ve also seen they do a Proving Unit, not sure on that either.
[automerge]1601502435[/automerge]
I also use a drummond tester sometimes to test if there is an induced voltage on a cable as sometimes one will encounter that and it can eliminate confusion as to how something is live when it should not be.
Sounds good, similar to Martindale from the looks of the kits online, obviously better quality.
Fluke for me, and I use the Megger 690 proving unit which is a solid build with magnetic base. One of our sponsors sells them for about£80 inc. VAT. Buy once...
The same unit here in Spain from RS is listed at €160!
And what’s wrong with this then??
One of the first jobs when starting, make your own voltage tester, pyro shroud, neon and holder and wire!
Accurate voltage measurement -
dim - not 240v,
normal - 240v,
bright as f - oops 415v
Used for years...
For some reason, it's not the preferred voltage tester now!
Another vote for the megger tpt320
I use a socket and see sp200 proving unit.
Spend on the tester, but proving units are much of a muchness
Looked at this several times and I'm convinced this is housed in a carrot and not a pyro shroud.
Yeah it's a bit old and been sculling round the bottom of a toolbox for years!
If it was a carrot, it would be rotten by now.
I am not sure i want to test it though, how times have changed, it was the right thing to use in the 70's, now scared to use it.
[automerge]1601542322[/automerge]
It does......
1977 - 2020 and still working, take that megger/fluke/martindale
....It looks like something at the bottom of a clinical waste bin,in a prostate operating theatre...
[automerge]1601544920[/automerge]
I have the TPT320 and the older TPT220...both very good bits of kit.
I have always used Drummond testers, Especially like their new LED ones. Bombproof.
[automerge]1601546253[/automerge]
Years ago when I was an SAP with a DNO the old Clyde Valley Power Company substations had the original home made testers in them. A Plywood box with two 60W lamps in series inside, holes in the front so you could see the lamps, Substation name signwritten at the top and a special bracket on the wall to hang it on, next to the rack for spare fuses. Wish I had kept one.
I’ve not seen the Drummond ones.
They look good the Drummond Kits:
Reply to Recommendations for a Voltage Indicator and Proving Unit in the Electrical Tools and Products area at ElectriciansForums.net
i need to purchase a voltage proving unit - i have seen Megger MPU690, Martindale PD690, and Socket and See SP400, and Fluke but difficult to...
Martindale voltage tester and proving unit, plus lock off kit for sale. All brand new and never used. I've come off the tools, hence the sale...
Am absolutely gutted, my Fluke 1587 insulation tester appears it's had an unknown fatal incident. I was doing some testing a few days ago and was...
Currently I’m using freeagents platform for invoicing and it’s decent and gets the job done but it’s lacking a few features. Firstly I want to be...
Hi everyone, Which proving unit kit would you recommend? Obviously would be better to don't spend a fortune. Kewtech, Megger, Fluke o Martindale...
5K
