F
foghorn
no voltage live neutral at sockets any ideas surley if lost 1 neutral would still have voltage on the other leg all neutrals are connected in main fuse box
have checked neutrals are connected in main fuse box which they are and checked sockets am back there tomorrow to try and locate the problem
that is the plan tomorrow however even if there is a break in the neutral i would have thought there should still be 230 as one leg still connected
A mouse could of got under the floor boards and eaten the PVC (as they can digest PVC) and then chewed through the neutral core without touching the cpc and thus the RCD if fitted would not trip, then if he got a liking for T&E he might of scampered along a bit further then stopped for another nibble and done the exact same thing on the other leg of the ring and hey presto no N at the socket.
yes i agree that is the plan tomorrow however what im asking is even if there is break in ring surley u would still get 230 as 1 leg still connected
- - - Updated - - -
kas1 i like your theory
Quite agree with you.
Has anyone been meddling with the sockets you are looking at as I find it hard to belive that you wouldn't loose the neutral on ALL of the sockets on ring.
What tester are you using?
Don't get obsessed with "there should be 230v down the other neutral",,, there isn't, you've proved it already.
Some Possibles.
1st neutral failed some time ago, 2nd failed recently.
The ring isn't what it claims to be and both neutrals from the C.U go to a J.B or socket/spur then off to the ring, but have failed at that point.
The 2 neutrals "connected" in the C.U are bad connections.
I'd be looking at the last one first.
ring fault
foghorn,
robd,
