Discuss separation of data , coax. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Have got a building to wire with data and coax with the usual power. Am going to put in a trunking system. the question is can i run my data for IT sockets in the same compartment as tv coax cable??
You need to check the voltage rating of the coax.
If it's rated at 300V, then yes you can run it with the power.
If it's rated at 50V or 100V then no you can't.
engineer54. he's in the wirral. that's like the outer planets. have to get it flown in across the mersey.
sat. cable is ideal. it's far better quality than the tv coax.
Reply to separation of data , coax. in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
