Search the forum,
Discuss Siemens rwb29si central heating timer in the UK Electrical Forum area at ElectriciansForums.net
I
ICE
Hiya all you good looking sparks,
I have a Siemens rwb29si central heating timer and it is stating "service due" and has stopped my heating from working, how the f#€¥ do I reset it?
thanks
- - - Updated - - -
I have googled it but with no luck
You need a code, which would have been programmed in when it was installed/last serviced by the fitter.
No idea about Siemens, but on the Honeywells with that feature, there is no way of resetting the PIN number, if you've lost the number, it's a new programmer.
As yours is carrying on working, it shouldnt be a problem, they can be set to turn off, and not come back on again, if that happens, you are stuffed, so new programmer again.
Reply to Siemens rwb29si central heating timer in the UK Electrical Forum area at ElectriciansForums.net
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
A question if I may before I dive in. I have an old gravity fed CH system which thanks to members here in the past - works very well. It has a...
Hi - looking for opinions please so that I respond reasonably rather than as I would actually want to. Had a towel rail in bathroom. Replaced it...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
