Discuss single phase to 3 phase in the Australia area at ElectriciansForums.net
C
chloebear
Hi all,
I hav a requirement to convert a single phase supply into a 3 phase supply - the feed cable from the main dis board is 25mm SWA 3core and I require (strangly enough) 4core as a minimum to convert the board to 3 phase - the question is, would it be acceptable to run a new 2core cable for Neutral & Earth leaving the 3 existing cores as the 1/2/3 phase cores????????
The run is about 70 metres and to pull in a new 4 or 5 core cable will be a problem.
Any thoughts and guides on theis would be greatly appriciated.
I would say not, due the possibility of induced EMF. Obviously will have the seperate armour of each cable plus how they are glanded....in to a metal enclosure for instance.
Also the route of this additional cable would have to follow exactly the route of the existing one so I would suggest a new cable anyway.
Same here new cable needed.
thanks all for confirming my initial thoughts - its nice to have it confirmed, even if it is somewhat of a pain in the rear so to speak.
Reply to single phase to 3 phase in the Australia area at ElectriciansForums.net
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
I have a single phase stainless steel pasteuriser that has two control boxes attached to it. One box houses the control for the electronics and...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
Hi everyone, I have been asked to pull in some new 3 phase supplies for 7 new welders which do not require a neutral connection. The client has...
