Y
YTSOxford
hi, have to wire up one of those whirlpool baths for a client. It comes with a 13amp plug and with reading the new rags I am taking it as that i can put an outlet or fcu under the bath, since its only accessible with a tool. Is this correct???
The whole board will be RCD protected btw. Or shall I run a radial up the other side of the wall to the bathroom, and connect the bath through the wall to an FCu. Help appreciated as always.
Thats regs! sorry!
Yep, that's fine. As long as all equipotential bonding is in place and the circuit is RCD protected then that is fine.
Thanks cirrus, so a fcu under the bath is fine.
I have only main protective equipotential bonding in place. Are you lot still supplementary bonding?? The motor to the whirlpool does however have a fly earth, i would imagine that that should be supplementary bonded?
Under the bath is zone zero if a tool is required to access it. If RCD protected supplementary bonding is not required
erm.....no it isnt
if a tool is required to access then its OUTSIDE the zones, regardless of 16th or 17th
Zone zero is IN the bath!!!;)
Hmm, how's the head???:)
dont know about 'is 'ed, but mine is banging
i was doing allright, then my nipper came in about 11ish with his mate, woke up this morning, the fridge is empty of 'bow, the spicey rum is gone, the single malt is gone, and that bottle of 80% proof rum from somewhere overseas is looking a lilltle sorry for itself
she was REALLY impressed:o
