Hi looking for some advice
Guy at work has been jointing existing street light feeds to be fed from another position, now he’s connected at the street lights the same within the joint he’s used brown as line, black as earth, grey as neutral now he’s been back to test they all work but none have come on, each street light has its own RCBO, now I’m thinking that they must have used black as neutral and grey as earth as I noticed it on the same job but on another part of the site ,now wouldn’t they trip once the photocell has activated? He hasn’t been back to check cut outs as he went back to test up.
As long as the rcbo has equal current on the live and neutral as seen by the device.
It will not trip.
Surely If the Earth and Neutral are reversed then the RCBO will trip immediately the power switches via the photocell as effectively only current flowing in the Line and Not back through the Neutral so there would be an imbalance straight away. Does anyone do a Cert? Recording R1+R2 values? I agree with goasis
I thought this too apparently not, and he went one day to connect didn’t test and was going back again to test everything
[automerge]1574408594[/automerge]
I would have thought once photocell activates then the RCBO would trip as there’s no load on it until then
London
United Kingdom
Street light joint problems?
Bradley6969,
Pete999,
