Currently reading:
Surface mounted box.
Discuss Surface mounted box. in the UK Electrical Forum area at ElectriciansForums.net
Fellow Sparks,
My sister has asked me to install a spur socket in her home.
I'm going to install a surface mounted box and run the cable via trunking from an existing socket.
Is there any sort of surface box which I can install over the existing socket box which has been embedded in the wall?
I've checked various sites but all I'm getting is the 1 gang to 2 gang convertor box. I need one that will screw securely to the wall and have holes aligned to the existing lugs in the metal box.
Any help is much appreciated.
ZippyMo
Trainee Spark.
Hi @ZippyMo , why not just use an extension lead the plugs into the socket?
I'm not quite sure what you mean by this. Could you elaborate.
Use a mini trunking / conduit box
They don't explode like the standard box, when you tighten screws, they're a soft plastic.
You'll have to mount it slightly higher /lower than centre to be able to get screws into the original box.
https://www.NoLinkingToThis/p/tower-mini-skirting-trunking-32mm-1g-surface-box-pack-of-2/33772
Or there's this;
MK surface mounting frame K2134WHI (single)
Secures over a flush point and enables fixing to the flush lugs and an accessory on the front, same depth as minitrunking, double available as well. I normally use long M3.5mm accessory screws through the unthreaded lugs into the lugs on the flush box, that way the accessory is secure onto the metal backbox rather than fixed to the easily broken plastic frame
I was just about to suggest the same thing as above, can be awkward as everything likes to move around so I tend to put a couple of fixings through too, just to make positioning easier and not to put all the strain on the original box lugs which can be flimsy at best!
Use a converter and give her a double socket then spur from that.
Have you checked existing socket is on rfc and not a spur already?
Yes the original socket is a rfc located
Yes socket is definitely an rfc.
Reply to Surface mounted box. in the UK Electrical Forum area at ElectriciansForums.net
