Z
ZippyMo
Fellow Sparks,
My sister has asked me to install a spur socket in her home.
I'm going to install a surface mounted box and run the cable via trunking from an existing socket.
Is there any sort of surface box which I can install over the existing socket box which has been embedded in the wall?
I've checked various sites but all I'm getting is the 1 gang to 2 gang convertor box. I need one that will screw securely to the wall and have holes aligned to the existing lugs in the metal box.
Any help is much appreciated.
ZippyMo
Trainee Spark.
Hi @ZippyMo , why not just use an extension lead the plugs into the socket?
I'm not quite sure what you mean by this. Could you elaborate.
I think he means to convert the existing flush socket to a surface one - so that he can then take a length of trunking from that to the new surface mount socket which he is going to install.
Reactions: DPG
Use a converter and give her a double socket then spur from that.
Have you checked existing socket is on rfc and not a spur already?
Use a mini trunking / conduit box
They don't explode like the standard box, when you tighten screws, they're a soft plastic.
You'll have to mount it slightly higher /lower than centre to be able to get screws into the original box.
Or there's this;
Reactions: ruston and DPG
Trunking along the wall right up to the side of the existing socket, drill out the back of the trunking and enter by chopping a bit of the wall away and enter via a knockout with a grommet in it
  • Agree
Reactions: ZippyMo and James
MK surface mounting frame K2134WHI (single)
Secures over a flush point and enables fixing to the flush lugs and an accessory on the front, same depth as minitrunking, double available as well. I normally use long M3.5mm accessory screws through the unthreaded lugs into the lugs on the flush box, that way the accessory is secure onto the metal backbox rather than fixed to the easily broken plastic frame
I have had to do a similar thing.
I use PVC back boxes (like in snowhead's post) and use a 4mm mm drill to drill out the 3.5mm screw threads and put long screws straight through to the metal back box.
Reactions: ruston and SparkySy
I was just about to suggest the same thing as above, can be awkward as everything likes to move around so I tend to put a couple of fixings through too, just to make positioning easier and not to put all the strain on the original box lugs which can be flimsy at best!
Reactions: Davisonp
Email
Time zone
Last seen
Surface mounted box.
ZippyMo,
Midwest,
