Discuss Tails in three ph fusebox. in the Electrical Forum Canada area at ElectriciansForums.net
S
-sparky-pl-
Hi there, Three phase board, 125A isolator, are tails 25mm ok? Shouldn't the neutral be bigger?
Im having EDF monday, and i need to be sure.
Thank you
Ok mate i see what your saying 25mm ok for all meters if you have 3 x 100a ! only time it changes is if you have 300a fuses then its 35mm so 100a-to-CT is 35mm unless like some factories they might install a small sub-station outside (400A) and run 50mm tails but you have 3 x 100A so 25mm fine and Neutral is still 25mm.
Regards
Kung.
Sorry kung, yeh mate, tryin to do 3 things at once here, computer, print some stuff, and listen to missus moanin, imposs don,t yer think.
lol i know how you feel ! i was typing this long reply the other day when there wasnt any replies and by the time i finnished there were 16 replies saying what i typed lol and about an hr ago this other long reply just as i clicked submit the computor crashed grrrrrrrrrrrrr
just tell her the same as i tell my mrs ! threatern her with an rcd test just as eastenders starts ! works every time i had to do it 4 times last week to emmerdale ! that done the trick that and my macaw going for her hair.
Regards
Kung.
Reply to Tails in three ph fusebox. in the Electrical Forum Canada area at ElectriciansForums.net
Hello All So I'm not long out of my college days and unfortunately I didn't have a lot of exposure to three phase and commercial wiring systems...
Hi we have been asked to run a 3 phase supply into a boiler house to feed a DB fed from next to the existing meter. Would we need to install Tails...
Hi all, My question relates to the omission of overcurrent protection (specifically overload and fault protection) at the origin of an...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
Hi, I’d appreciate views on the fuse board. https://ibb.co/xj0BtZt It’s been completely rewired and I’m unhappy with the quality. I’ve...
14K
