G
Graham Hyde
Went on a job today to an HMO to replace a broken cctv camera outside.
the landlord of the house is too tight with his wallet to change the consumer unit to an Amendment 3 metal CU. instead he has enclosed the old wylex plastic CU into a metal enclosure. although he is willing to fork out on cctv so he can in his words 'monitor' the tenants!
The plastic CU has the mains tails going through the one gland entry point which is as i was taught in college and on my apprenticeship. This is not i believe so much an issue on plastic enclosures but on metal enclosures prevents eddy currents.
However, given the landlord has enclosed the CU in a lockable metal enclosure(which has no earthing ) to meet the new criteria, he has the mains tails coming from the isolator going through separate holes, rather than a combined entry point, this surely now makes the metal unit holding the CU in breach of the regs... the line and neutral are in separate glands as is the earth- i don't see the earth as the issue though. all other wires leaving the CU exit through the back and run up inside the cavity wall.
I asked him who did the job and he was a bit non committal about it and seemed very vague, i suspect he either did it himself or got it done on the cheap. the guy appears to cut every corner possible and
have enclosed a picture trying to explain what I am saying. Didn't think to take a picture at the time, its something i have been thinking about since,
Anybody have thoughts on this?
