Search the forum,
Discuss Tell us about your faults! in the Australia area at ElectriciansForums.net
One of his replies...
"Oh dear, if you do this job as a living rather than "learn" it out of books you will realise that the Ze referred to is the Ze of the db not the installation. Therefore removing the earthing conductor will result in an infinity reading. As for the voltage stick not failing to work between two successive tests, seconds apart and the coincidence of a failing disconector, the probability of those events is vanishingly small. I have to job to do !"
Hahaha...quality!
What a legend!! Never new time could be used as a proving unit!! That's cheaper ;)
Also since when has zdb included bonding...........
From the response he hasn't got any quals or knowledge!!
Thing is people use on-line videos to learn how to do tests, I know when I was learning to use my Megger I watched a few just to get the jist of it.
He must have a few quid lying around, two MFT's to play with...
found this.. changed for trip types, couldnt leave it! (luckily i had some from a cu change)
asasa.JPG customer didn't want to know.. :-(
Reply to Tell us about your faults! in the Australia area at ElectriciansForums.net
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
