I recently bought 1 gang British electrical socket. Before wiring it up,is it possible to test whether the socket work? I tried to use a multimeter using the continuity test by connecting it to L and N but there is no sound coming. Does that mean that the socket is broken?
Get an electrician in to fit it for you, you obviously have no idea of what you are doing.
You could test continuity between the live input to live output and the same with the neutral and earth. Not much point if its new though...
Since when did 1 gang 13 Amp sockets have input and output terminals?
PS Spot the OP's location
Asia
Testing electrical socket
Bori,
telectrix,
