Discuss Testing of DALI Systems in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It is digital. Digital Addressable Lighting Interface. You can dim and switch on/off lighting with it.
Edit Andy: Thanks mate, I have amended it to addressable now.
Thanks for the reply's. I was wondering how you carry out insulation testing of the outputs to the light fittings, as I understand it you will be unable to do it from the point of supply through the Lighting control modules.
Reply to Testing of DALI Systems in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
