Discuss Testing of DALI Systems in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It is digital. Digital Addressable Lighting Interface. You can dim and switch on/off lighting with it.
Edit Andy: Thanks mate, I have amended it to addressable now.
Thanks for the reply's. I was wondering how you carry out insulation testing of the outputs to the light fittings, as I understand it you will be unable to do it from the point of supply through the Lighting control modules.
Reply to Testing of DALI Systems in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi All DALI lighting system distributes circuit via LCM's, for electrical test, do you stop at the LCM or light point. how do you carry out...
Good morning all. I have an issue with some dali lighting. Basic system as far as i can tell. Dimmer, controller and 8 button switch. No other...
5K
Hi everyone, I am new to photovoltaic system installation, can you guys give me some advice. Currently I plan to purchase a Maysun Solar 800W...
Hey, with regards to DALI Emergency Lighting Automated testing via a control system, does anyone know how best to overcome a fitting that is...
