Discuss Third Party Certification in Wales??? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Are you talking about 3rd party verification?
Unregistered installers should not themselves arrange for a third party to carry out final inspection and testing. The third party – not having supervised the work from the outset – would not be in a position to verify that the installation work complied fully with BS 7671:2001 requirements. An electrical installation certificate can be issued only by the installer responsible for the installation work
Your last post is saying that if you are unable to self certify and notify, you need to employ the services of a Stroma or Napit member who is registered for 3rd party certification. You should not assume that you can employ someone to undertake an EICR, you need an EIC
Sorry I'm not explaining myself properly.
I Can Issue EICRs & EICs myself as I am qualified to do so but it seems Wales has a different set up.
Notification cannot be carried out by a third party
England operates using the 2013 edition of Approved Document P. This reduced the number of special locations and introduced the concept of Third Party Certification. The process goes like this... you engage the services of a spark, spark designs the installation, you install it and they inspect it at key stages they specify, then they inspect and test it, issue an EIC and a building control notification I believe.
Wales operates using the 2010 edition of Approved Document P, which has a much bigger list of special locations and no Third Party Certification.
In either location you can issue EICs, MEIWCs and carry out EICRs providing you are competent to do so. You can notify the council of your plans ahead of time pay them a shed ton of cash to inspect and sign off, show them your quals and hope they deem you competent and then notify them ahead of time but just send them the EIC and have them sign off or be a member of a scheme, do the job and notify yourself after the event.
So yes, your statement 'Notification cannot be done by a third party' is correct.
Reply to Third Party Certification in Wales??? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
NAPIT Certification Scheme Third Party Certification
Is there anybody out there in NAPITs Third Party Certification Scheme who would be willing to certify a new consumer unit I am wanting to install...
I commissioned an EICR to be done on a property that is in Wales as this is now a requirement in order to let on any new tenancies after 1st...
Hi Folks , Just looking for a bit of advice as I'm looking to get back on the tools so please bare with me if this is a bit long winded. I'm a...
Hi, I would like to do some minor domestic electrical work while I am completing my NVQ level 2 in electrical installations. I have the 18th...
5K
