Oct 27, 2018
130
35
103
Swansea
Business Name
Michael Jones Electrical Inspection
I have just gone through Part P (Wales) and if I'm reading it properly you can only issue EICR as a Third Party.
Anybody else come across this?
So you can't EICR your own work? Seems sensible idea to me.
Are you talking about 3rd party verification?
Unregistered installers should not themselves arrange for a third party to carry out final inspection and testing. The third party – not having supervised the work from the outset – would not be in a position to verify that the installation work complied fully with BS 7671:2001 requirements. An electrical installation certificate can be issued only by the installer responsible for the installation work
Your last post is saying that if you are unable to self certify and notify, you need to employ the services of a Stroma or Napit member who is registered for 3rd party certification. You should not assume that you can employ someone to undertake an EICR, you need an EIC
Sorry I'm not explaining myself properly.
I Can Issue EICRs & EICs myself as I am qualified to do so but it seems Wales has a different set up.
Notification cannot be carried out by a third party
If you have time or the will, check out Third Party (England) and then (Wales) In Part P
England operates using the 2013 edition of Approved Document P. This reduced the number of special locations and introduced the concept of Third Party Certification. The process goes like this... you engage the services of a spark, spark designs the installation, you install it and they inspect it at key stages they specify, then they inspect and test it, issue an EIC and a building control notification I believe.
Wales operates using the 2010 edition of Approved Document P, which has a much bigger list of special locations and no Third Party Certification.
In either location you can issue EICs, MEIWCs and carry out EICRs providing you are competent to do so. You can notify the council of your plans ahead of time pay them a shed ton of cash to inspect and sign off, show them your quals and hope they deem you competent and then notify them ahead of time but just send them the EIC and have them sign off or be a member of a scheme, do the job and notify yourself after the event.
So yes, your statement 'Notification cannot be done by a third party' is correct.
  • Informative
Reactions: Michael J
Sparky Chick explained it perfectly
If your op what’s the difference between Part P regs in England & Wales, you would have received a quicker answer.:)
Not from you though
Swansea
Business Name
Third Party Certification in Wales???
Michael J,
Midwest,
