OP
Discuss TN-S & TT on same installation what should I class it as? in the UK Electrical Forum area at ElectriciansForums.net
True, live and learn.What would you recommend grind rod down and fill hole or just connect to MET with new clamp and 10mm cable.
Mike...can you secure those main bonding conductors (clip them) please...All sorted new clamps on Gas & Rod and new METView attachment 18088
it looks all leathered where its bent...Gas feed to cooker through to other room
Yep aggree as however PFC could be as high and should not 16Ka on a 230 supply as per OSG page 70 As said May be high so a measure to ensure devices meet capasityI doubt he will have any higher than 3-4Ka maximum, even if he's near the Dno tx.
Reply to TN-S & TT on same installation what should I class it as? in the UK Electrical Forum area at ElectriciansForums.net
