Discuss Underpinning knowledge questions, EAL level 3 HELP!!! in the UK Electrical Forum area at ElectriciansForums.net
C
CheshireSpark
Hi all, I'm currently working my way through the EAL knowledge questions for the second time due to my assessor 'losing' my first attempt. Due to not being in college anymore, no access to BS7671 and a constant switch of college assessors it is hard to get any extra help, the wording of the questions is unbearable and mind-numbing, if anybody could help me out with the answers, a digital copy, or just to re-word the questions it would be a MASSIVE help and would be greatly appreciated!
Questions are as follow:
Q1. what are the implications for relevant parties of carrying out an isolation?
Q2. what is the importance for using personal protective equipment and safe appropriate tools for specific jobs?
Q3. what are the hazards associated with using electrical equipment and plant including their lifting, handling and fixing?
Q4. What part of the IEE wiring regulations as specified in the lasted British Standard for Electrical Installations are relevant to types and uses of wiring systems, writing enclosures and equipment?
Q5. Where can you find out about the principles of electrical theory, which allow for safe installation of electrical wiring systems, wiring enclosures and equipment?
Q6. What are the requirements of the installation specification with regard to the type of site required?
Q7. what is the best practice with regard to methods of testing, their inter-relationship and sequence?
Q8. what is the importance of accurate labeling and recording of the test?
Q9. what are the characteristics of different types of cabling and component and how would they impact on the test?
Q10. what are the approved procedures and requirements for commissioning the installation?
Q11. what are the approved reporting procedures?
Q12. how would you catty out the tests and what is the effect on equipment not part of the fixed installation?
Q13. what testing takes place under live conditions? (got this one)
Any help would be greatly appreciated,
thanks for your time.
suggest you have a go at posting your attempts, then constructive criticism will follow.
You must have a copy of the 17th edition green book, it is a must for the EAL course, and you will have to carry with you as ( i was informed) you can at any time be asked to see if you have it with you on site
Try this for a possible translation:
What effect (good, bad, or operational) can isolating an installation have on the owners, users, electrician?
Why is it necessary to use PPE and proper tools, what would happen if you did not?
Give details of the dangers that may arise during an electrical installation covering electrical safety, heavy loads, difficult locations, use of tools, testing equipment and access, everything that you may encounter?
Which chapter of BS7671 describes the selection and erection of electrical equipment?
What documents cover the requirements for safety and design when installing electrical equipment?
If you have different types of site, domestic, commercial, agricultural, industrial, special situations how will the electrical installation be designed differently?
How should you go about testing an electrical installation why should you do all thtese test and why should you do them in the specified order?
Why is it necessary to put the right values in the right places on a well laid out correctly completed form?
What effects can be experienced when testing if you are using different cable types, eg. Twin and earth, singles, SWA? What effect can installed accessories, sockets, fused connection units, isolators, dimmers, RCDs, etc. have on your testing?
To what specifications, documents, regulations, etc. will you work to safely and compliantly complete the testing required to put a electrical installation into service. How do you then do this?
Pass: need more information may be required documents, may be building regulations, may be health and safety.
How do you undertake testing of an electrical installation and does this include plugged in equipment?
Live testing takes place under live conditions!! But you already knew that!!
Reply to Underpinning knowledge questions, EAL level 3 HELP!!! in the UK Electrical Forum area at ElectriciansForums.net
Hi, Currently working my way through my NVQ portfolio (Nearing Completion) but getting stuck on how to complete the following criteria due to...
Good morning all I have a summer assignment that I need to have ready before the 4th of September and I have 4 tasks that I have yet to complete...
Hi, Just wondered if anyone knows whether there is such a thing as a distance learning version of the level 3 (C&G or EAL) Electrical...
4K
Hey there, I'm here to ask about receiving some careers advice. Last year I was studying Level 3 Electrical Installation and after completing and...
