G
Gunnspark
Hi. I'm new to LED wiring and am wondering how to work out volt drop when using 24 volt drivers and 2mm elv cable. The length of run is about 20 metres. I've read that the 4% stays the same as 230v but what would be the maximum length of cable that could be used?
There is a formula and there are reference tables however 2mm is not in any of my references. Is 2mm the outside diameter of the wire or the cross-sectional area of the conductor?
Vdrop = IR. If it is a 2mm CSA wire you'll need to go to the manufacturers website to get the resistance per meter.
*Edit* For apporximate reference purposes 2mm CSA is pretty close to 14AWG size.
Whats E? I'm looking for volt drop in elv circuit. How could you possibly get that from amps (I) x impedence (z)?????????????? I really think your just taking the micky
If the driver is a constant current type then volt drop doesn't really matter as long as the LED gets the right current.
volt drop on elv LED wiring
Gunnspark,
Marvo,
