Hi guys,
came across a fault yesterday on a job where I was getting 15v between neutral and Earth at two sockets on a ring main.if u need anymore details let me know.
i am unsure what would cause this and want your expert opinion as I have never come across this problem.
the installation is an old 3036 board no RCD
TNS system
your replies are appreciated
it could be a phantom voltage. try with an analogue meter. if it's still there, check all earthing and bonding and the cpc connections on the socket circuit.
Hi guys,
TNS system
What was the voltage between neutral and earth, measured at the terminals in the board?
Nottingham
United Kingdom
Electrical Engineer (Qualified)
Voltage between Neutral and Earth
Sb8389,
mojorebel,
