Hi Im working in a staffed residential home (for severe learning difficulties/disabilities residents) they have a new onsite tanked gas supply being installed to supply two domestic sized gas boilers in seperate locations, which will replace the existing big oil fired boiler. I need to clarify if the new supply needs a gas solenoid interfaced with the fire alarm and if so whether it needs to be a manually resettable solenoid if its only supplying boilers. Also I need to suss out if any other additional safety precautions (over and above that of a normal domestic setting) need to be implemented in the 'plant rooms' where these boilers are going e.g. Duomo gas safety system or the like. We look after the fire alarm and will also be installing the boiler control
