Discuss where is battery located please, emergency lighting in the Lighting Forum area at ElectriciansForums.net
gordon30
Hello, this emergency light does not come on when power is cut. There is a red light on when house has power, indicating power to the unit. The bulb works fine. I thought the battery may need changed. It has not been changed for a long time.
How ever I can't see where the battery is. Is it located under the white board held on with 3 screws?
Thanks,
Gordon
It is likely to be behind the white gear tray. The battery is on permanent charge whilst the mains power is on, if it does not operate under mains failure the most cost effective thing to do is completely replace the fitting.
thanks, I had thought I'd be cheaper replacing the battery only as opposed to whole unit?
There is no guarantee it is the battery. The red LED charge indicator suggests it of some age, they are now green. Just replace the whole thing.
okay.
We have two new ones that are green, when off there is a green light. They are approx 2 years old. When power goes off one lights up properly the other remains off. I thought the batteries had a 4 year shelf life. I assume in this case best to change the bettery in the one not lighting up when power cut? Thanks for your help.
it's a crappy cfl fitting anyway, so replace with LED
These ones are LED and say battery good for 4 years. So think this must need the bulb replacing.
[automerge]1582835271[/automerge]
Sorry mean battery replacing, bulb is good
If an led fitting has failed again it is more cost effective to totally replace it.
That depends on the cost of the fitting, just because it is LED it doesn't necessarily mean it is a cheap fitting.
Plus replacing a whole fitting when only a battery is required is unnecessarily wasteful.
I agree and aesthetics may demand a repair but his picture shows a standard light fitting picked up for little cost from most wholesalers.
Reply to where is battery located please, emergency lighting in the Lighting Forum area at ElectriciansForums.net
Bit of an embarrassing one here but wondering if anyone can help. Was called to a doctor's surgery yesterday to replace the battery in an...
Hello Forum! The building I maintain has some fluoro fixtures with battery backup ballasts. There is a 3-way switch at each end of the hallway...
I have halogen lights in my kitchen under the wall units, there are ten lights altogether bulbs are either 10 watt or 20 watt G4 bulbs ( not sure...
Afternoon all... The customer has a number of small green lights in the ceiling that are always on. This is a bed and breakfast/hotel. I had...
5K
Hello, Behind a tiny door in our under stairs cupboard we’d like to build a miniature room in which a little light would come on when the door...
