kreatiff63
I've installed a ceramic hob and would like to check if I've done it correctly as I have a replacement coming tomorrow and would like to get it right.
The configuration is as follows:
40A circuit breaker feeds original wall plate and is now burried in the wall and has the new 6mm cable connecting to it. From this I've simply wired the new 6mm cable into the old wall plate (in the wall), and run this under the floor to the other side of the room to another wall plate. From this I have the heat proof 2.5 cable feeding the hob. The hob worked when checking it, but then failed to turn on after boiling some water last night. I have a replacement coming tomorrow and want to get it right if I've made any errors
Ceramic Hob:
Baumatic (Hoover/Candy)
30A
6.1kw
Ceramic Hob:
30A
6.1kw
