Discuss Wiring Advice - Multiple supply lines into fuse box in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
All,
Usually a bit more prudent with this stuff, however I find myself unable to wire up a fuse box controlling a light. I'm also fairly sure a motion sensor light on the landing outside my front door is contolled by this box.
Photo attached. 3 supply cables from the wall and the wiring up to the switch. My attempts have resulted only in a tripped switch.
Any help much appreciated.
Vito
All,
Vito
Vito my Friend, you need the help of an Electrician on site to decipher that mess, from the looks of the wiring there may have been some overheating of the wiring, get help from a Sparky.
site visit required to determine what is what .
i got a westons vintage cider for light relief pm.then 3 x theaksons old peculier for 2nite. cutting down to this level could mean another 5 years of pension. :D
fair shout :) i was looking at picture on my phone without zooming in. but i have seen and come across light switches at skirting level. also had one on a ceiling! you'd be amazed at what people do in their homes
No offence meant but I'd recommend hiring a qualified electrician to take a look. As previously mentioned, it could be that the permanent-line runs to the lamp with a switch-wire to the light switch perhaps?
Reply to Wiring Advice - Multiple supply lines into fuse box in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
Hi, I'm adding American muscle's halo fog lights to my 2006 v6 mustang and am looking for a good place to connect the positive side to power the...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
