...in Scotland I believe you can notify or even take a short course to allow you to do your own resealing.
This is not the case for the rest of us...
It is for those in the area of southern England covered by SSE. Just talk to them nicely, tell them who you're registered with and they'll give you some temporary seals.
Life would be simpler if the DNO put in isolation switches they change the meters often enough so put in a switch at the same time then problem solved
First to admit my Inglish is crap and the day It kills me is the day Ill respect all those who pulled me for it... although its 50% predictive txt and 50% bad grammer.:dunce2:
But yes Route and Site!...
... and grammAr ...:lol::oops:
Life would be simpler if all meters were fitted with isolation switches on the customer side like gas meters.
Yes agree to the first part but its in the interest of the forum the advice given does not go beyond legal practice or advise unsafe practices, there's a safe practice method to do this and is the very reason why DNO often change and work live!!! but they wear the appropriate PPE too, something I'm sure the OP will not own, evident in the very fact he has asked the question, genarally in this industry of electrical work we do not get trained to work safely live but how to isolate safely so this is the advice to give.
Looking back over my apprentices of the last 5 I'd say only one would be competent and confident enough to do a live swap, the rest I would dread to think!!!
While we're on the grammAr..lol
Yes agree to the first part but its in the interest of the forum the advice given does not go beyond legal practice or advise unsafe practices, there's a safe practice method to do this and is the very reason why DNO often change and work live!!! but they wear the appropriate PPE too, something I'm sure the OP will not own, evident in the very fact he has asked the question, genarally in this industry of electrical work we do not get trained to work safely live but how to isolate safely so this is the advise to give.
Punctuation?
Freeze Punks ! This is a bad English raid !
They'll need the army, not some irate plebs (sorry I mean fine upstanding, honest policemen/ women/ persons).
Hi, so cutting and re-sealing is the way forward as it's an urgent job[/QUOTE
So what exactly is so urgent that first you would like to risk your life over it, and then when talked out of that intend to break the law???
Give the whole story, and the experienced chaps on here will give you a tried and tested answer to your problem.
Like why is repositioning a CU "urgent"
Thanks Philip, has any Electrician ever been prosecuted for pulling the service fuse?
I don’t know if there have been any prosecutions, as a forum a system of persecution should be introduced to punish members who ask about removing a service fuse.
we can pull a main fuse but never the meter seals and that came from one of Scottish power 's bosses
I understand that the agreement is for NICEIC Approved contractors or the SELECT equivalent, not the millions of fly by night cowboys that exist in Scotland. Years ago I had to show my local manager that I had the safety gear required.
Hi, I'm not bypassing the meter... I'm repositioning the consumer unit 3 foot up the wall. I'm a fully qualified electrician with 2330 levels 2&3, the 17th edition regs and the 2391. I just asked a question and was hoping somebody would offer a constructive answer... not accuse me if being a criminal!
There's brains here that aint been tapped! If you have all those quals then you should know the correct/safe procedure. Prove Darwin wrong...
