Hi,
I have just managed to loose my ratchet crimper set, I am sure I left them at a customers house but they deny seeing them.
I had the draper expert set in a case with ratchet crimper and lots of different crimps.
I need to replace it, but was wondering if I should get one of the crimpers with interchangeable crimp jaws or just go for the standard crimper which only does insulated crimps.
Would be useful to get any suggestions on a recommended brand as well.
Hi Mark.
I've not used the interchangeable crimper but they look smart.
When you buy a pair have a look at the jaws. Some only crimp on half the jaw, which means you have to crimp twice.
James
Hi Mark.
James
Some of the ratchet crimpers for insulated crimps have jaws that are only designed to be used in one direction, the die only crimps the connection to the conductor not the insulation they don't need to be crimped twice and produce a better crimp as you are not damaging the insulation of the crimp by compressing it to the same depth as the conductor.
see my post in the insulated pliers thread. the pic of the ratchet crimp tool.not cheap but look good. and haupa do one with interchangeable jaws.
I have A pair of Cembre crimpstars for the red yellow and blue crimps. They seem like decent quality. They make others as well for bigger/uninsulated crimps.
I need crimpers for insulated crimps, butt crimps up to 16mm and ferruuls. Is there an all in one or is it separates? Any suggestions? I like the look of the knipex ones.
Hammer?
Seriously though you really need the proper crimpers for each type of crimp, although IMO the 'pliers' type crimpers are OK for ferrules because the terminal screw will be screwing onto the crimp - you're not expecting it to be holding two cables together under tension.
ive got a set of knipex ferrule pliers
cost me £20 and go from 0.25-16mm
my lasy ck set only went upto 2.5 but the knipex go lower lol
Hi,
Thanks for all the replies, I seem to be drawing the conclusion that very few sparks use the crimpers with the interchangeable jaws. The Only reason I was looking at them is the convenience of having everything in one pouch.
I only use the crimpers for eyelets and butt connectors so maybe I should just be looking at stand alone tools of a better quality and maybe a pair of ferrule crimpers as well.
Thanks its given me some good info.
Yeah I know, and I don't crimp or touch anything live.
you could use that argument for why do I have everything else as VDE? I like the handles. Cutters, pliers etc, everything is VDE
I have done a search for these and I can only find this model in the US, where can you get these in the UK for £20?
They do look good.
Mark.
search for 97 71 180
thats the code for them, they are now £26 on amazon but worth it.
there very good and i find them easier than rachets.
a good tip with knipex is always look at the code on the handle, it makes comparing prices a lot easier
(i cant find them for under £26 now but i know i paid less)
there worth a lot more imho though
It looks like they have changed the design, the only ones I can find now only crimp 1 - 16mm not .25 - 16mm.
Very annoying.
use the part number only in seach or knipex then part number
your looking at a different model, knipex makes different versions of the same tools that look very similar to each other
I was looking at the picture of the tool (same as above) and it only covers from 1 - 16mm, I guess the pictures is wrong.
Pleased about that I will get it ordered.
Thank you
i've got this one for when my teeth are aching. haupa. 0.5mm - 16mm.
Are the Knipex and Haupa ones pictured in this thread any good for copper lugs, or just really suitable for ferrule ends ? I'm looking for a more compact tool for lugging onto earthing and bonding cables up to 16mm and these look as if they might do.
no, ive tried it with through crimps and they split them.
what are you using at the moment?
For copper tube lugs you really want something with mechanical advantage/leverage.
Have you tried them on .25?, I do a fair bit on .25/.34 and find some crimpers don't live up to the specs and give me a loose ferrule I can pull the wire out.
sorry i havent tried it on .25 but i havent had a loose one yet (if you need to the very ends are pliers so could always give them a squeeze)
we tend to use 0.75 minimum upto 6mm depending on the length of run
nah these kind are better, they do 10-300mm and easy to use
a guy that used to work for us had a set and they are great
(not this brand but looks very similar)
Cheers Shanky but I'm just after something small for my domestic work.. those are a bit overkill. I have used those hydraulic type before and they are amazing, the set I used cost a fair bit more than that though.
Wales
Ratchet crimper
Electrical Tools and Products
markadams,
rapparee,
