Currently reading:
Which consumer units are best
Discuss Which consumer units are best in the UK Electrical Forum area at ElectriciansForums.net
I have a very old Wylex fuse board which is need to bring up to current standard Amendment 3.
I believe my property is supplied using a TN-S
I'm looking for a new consumer unit that is 11 or 12 way but not sure which brands are best as I plan on going for all rcbo.
So far I've seen Schneider, Hager and Wylex units
Schneider do one called Resi9 that's top of range but can't find any places that sell them, I can only see the Easy 9 for sale
Hager do one called Design 30
Wylex seem well stocked but I hear their rcbos are over sensitive and trip a lot, also they have had a recall in the past so I'm not sure on their quality in today's climate
I'm just wanting some advice on what you guys like to install, money isn't an object so I'm not after any budget stuff
Can anyone post pictures of their installs, be it cabinets or new metal consumer units
A consumer unit is a particular type of distribution board which is intended for simple single phase domestic use.
There are definitions in BS7671
No, BS7671 says 'principally domestic premises' - it is not exclusive. Although I still say that a dist board generally feeds distribution circuits to other sub-boards. Daz
yes and what im saying is acti9 Type A is a single phase only board thanks to the isobar so is technically a consumer unit as well
Are you certain that it has the type testing to be a consumer unit? Do they not make a direct connection kit for it?
If you really want to be pedantic it is an isobar4 distribution board which uses acti9 protection and control devices.
Nice to see pedantry being demonstrated at it's finest! I think the difference is purely semantic, but as a rule 'Consumer Unit' is language is use with domestic customers, other than that it's Distribution Board.
The regulations make a distinction between the two along with all manufacturers. I think it's a bit more than just semantics.
The original 'consumer unit' was specific to domestic single phase installations and incorporated the cutout, metering, main switch and circuit protective devices into a single unit. This was in the 1950s.
What I can't find is a more up to date definition, other than the one in bs7671 which is not overly specific
ImageUploadedByTapatalk1431634389.086130.jpgImageUploadedByTapatalk1431634414.047782.jpg
View attachment 29126View attachment 29127
I know what you mean, but in reality it's semantics isn't it? When a fellow sparks says CU or DB you pretty much know what they mean...
IMO it seems like all CUs are DBs, but not all DBs are CUs...
Cough! Getting back the original thread; Wylex, Crabtree (same group), Schneider, Hager & MK Electric are all offering their new 'Amendment 3' domestic consumer units. I'm not sure I would include any others IMHO. My local wholesalers usually stock from all these manufactories, but only have Wylex currently available off the shelf, and only in a couple of sizes/flavours.
Seems that metal 'Amendment 3' boards are rarer than rocking horse pooh at the moment, so OP, you should speak to your electrician to see what he can obtain or wait a while till the shelves get stocked up and the guys here, can give their views, once they fitted a few. IMO the Hager one seems to of had some thought put into the design, the rest seem to have put the contents of their plastic CU's into a metal box.
im surprised no one has brought one out with a layer of fire mastic covering the inside XD that would contain the fire.
if there is a fire it will expand and cover the lot
what good is a cable grip for the tails if the problem is a loose or bad termination
Reply to Which consumer units are best in the UK Electrical Forum area at ElectriciansForums.net
