S
Slowbutsure
Hello
Been disconnecting a few SWA glands from some 20mm galv conduit boxes which are screwed down to steel purlins at high level in a warehouse.
I only have adjustable spanners!, and the gland body and back-nut are close together so 2 adjustable's don't work. For the 3-core 1.5mm SWA cable I'm using the nuts are 21mm 'across the flats' and the spanners must not be any thicker than 6mm!
No problem I thought I'll just nip down to my local electrical wholesaler who'll be sure to have SWA spanners. When I asked about SWA spanners I got a mystified look with comment 'never been asked for those before', I tried several others with similar response's.
Does anyone use the correct spanners for SWA's and if so where do you get them?
Best regards
Slowbutsure.
Hello
Best regards
Slowbutsure.
No I mustn't
I had this problem when I was an apprentice and couldn't find a spanner to fit so I made one out of 2"x 1/8th flat bar,in fact it was only last week when my apprentice had the same problem and after digging it out and dusting it off it made light work of the stubborn glands, he's going to make himself one now! It's not the prettiest of tools but hey, it works!:)
A picture would be good , I for one would be interested in seeing this !
you can get slim adjustables
there are similar on amazon etc
to be honest i tend to use grips on the inside or hammer and knocking driver
QUOTE=Aindowsimon;1149929]A picture would be good , I for one would be interested in seeing this ![/QUOTE]
Like I said not the prettiest.
Some other tools that were made around the same time:
Obviously I didn't make the 'footprints' but thought it worthwhile showing the tools that were 'hip' at the time!:)
The other tools in the picture are a pair of bush keys (20mm/25mm)short and long reach and a locknut spanner that covered sizes from 32mm up to 50mm.
View attachment 30874View attachment 30875
The other tools in the picture are a pair of bush keys (20mm/25mm)short and long reach and a locknut spanner that covered sizes from 32mm up to 50mm.[/QUOTE]
with sites like this its tempting to get parts made
www.protolabs.co.uk/cnc-machining/cnc-milling.
Can I just add that the two bush spanners that I made are of little use now due to the skimpy bushes available today, I have ck bush key for these which works very well.CK TOOLS ELECTRICIANS 190mm (7.1/2") SOFT GRIP CONDUIT BUSH WRENCH - SPANNER | eBay
i got that from elex last year.
one problem with SWA locknuts is the space around precludes the use of grips or adjustable spanner. the solution is here:
LOCKNUT SPANNER,CONDUIT, NOT, BUSH SPANNER,ELECTRICIANS | eBay
I've got some of these tbh not worth the money as I hardly use them as they only fit one or two manufacturers
As before slim and normal bahco for smaller glands and a pair of nws adjustable wrenches for larger! I'll try and post a pic of these they were £15 each! But do larger glands very nicely
there 20-25+ each now the bahco ones
the problems with any sort of adjustable spanner is the width if you have the gland close to the edge or to an adjacent gland. also a lot of enclosures have a lip on the front, so you can't get the tool flat. end up with it slipping and barking yer knuckles on any metalwork in the vicinity.
thats one on the reasons i like the knipex pliers.
i tend to use grips inside to take then off or 10mm knocking driver
SWA Spanners
Electrical Tools and Products
Slowbutsure,
shanky887614,
